2000 passat remote window roll up?
turboneon
Member - Posts: 37
Posted: February 02, 2008 at 4:03 PM / IP Logged
Anyone know how to make the windows auto rollup and the sunroof close using and aftermarket system? I just finished putting the remote starter in and need to finish this one last thing.
I know interfaces exist for doing this with the oem fob, but I do not plan on carrying that one any longer.
Thanks.
chriswallace187
Gold - Posts: 1,661
Posted: February 02, 2008 at 6:36 PM / IP Logged
Question: Does this car roll them up or down when you hold the key in the door to lock or unlock? I know the later model VWs do but I can't remember exactly when they started.
If it does then you can hook auxiliary channels from the aftermarket unit to the lock/unlock wires. Program them to output as long as the transmitter button is being pressed.
If it doesn't, you will have to get aftermarket window/sunroof control modules to do window roll-up.
C Renner's Auto Electronix
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2008 at 6:38 PM / IP Logged
If you extend the lock and unlock pulses.... the windows WILL operate.
turboneon
Member - Posts: 37
Posted: February 02, 2008 at 8:47 PM / IP Logged
Chris, Yes they roll up when you turn and hold the key.
Thanks guys. That's the info I needed.
tedmond
Gold - Posts: 4,610
Posted: February 02, 2008 at 8:50 PM / IP Logged
neg on lock will rollup windows.
chadwa2003
Copper - Posts: 353
Posted: February 02, 2008 at 9:21 PM / IP Logged
Depending on the model of system you use you can use the aux outputs or the comfort closure feature on dei systems
turboneon
Member - Posts: 37
Posted: February 02, 2008 at 10:27 PM / IP Logged
It's a scyteck unit. I wanted one that was designed for an mtx car, and have had good luck with these in the past. I know I can set the channel 1 or 2 outputs to, I think it's a 10 second pulse. I wouldn't think I would have an issue if that pulse ends up being to long as I would think the car would have a safty incase you held the key turned to long creating the same type issue.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
