2008 Ford F-150 Alarm/Stereo Wiring
tweak master
Member - Posts: 14
Posted: February 04, 2008 at 4:59 PM / IP Logged
Does anyone have remote start wiring info for the 2008 F-150? DEI has info for the F-250 but not the F-150. Thanks for the help.
Twelvoltz
Platinum - Posts: 2,384
Posted: February 04, 2008 at 6:41 PM / IP Logged
Audiovox lists:
          #513820: 2008 FORD F150 2DR TRUCK WITH 4.2L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          LIGHT GREEN/ VIOLET          (+)          RADIO HARNESS
     Accesory          LIGHT GREEN/ YELLOW          (+)          RADIO HARNESS
               WILL BE PINK/BLACK ON XL AND STX MODELS.
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          LIGHT BLUE/RED          (+)          RADIO HARNESS
     LF Speaker (+)          ORANGE / LIGHT GREEN
     LF Speaker (-)          LIGHT BLUE/WHITE
     RF Speaker (+)          WHITE/ LIGHT GREEN
     RF Speaker (-)          DARK GREEN/ ORANGE
     LR Speaker (+)          GRAY/LIGHT BLUE
     LR Speaker (-)          TAN / YELLOW
     RR Speaker (+)          ORANGE / RED
     RR Speaker (-)          BROWN / PINK
     Steering Cntrls          OPTIONAL
     Speed Cntrl          YES
     Radio Security          YES
     Security
     Battery          LIGHT GREEN/ VIOLET          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLUE/LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          RED / LIGHT BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BLACK/ LIGHT BLUE          (+)          AT VEHICLE LIGHT SWITCH HARNESS
     Domelight Super          BLACK/ BLUE          (+)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Latch          BLACK / YELLOW          (-)          AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
               PIN #4
     RF Latch          BLACK/ PINK          (-)          AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
               PIN #5
     Parking Lights          BROWN          (+)          AT VEHICLE LIGHT SWITCH HARNESS
     Convenience
     Headlights-Lo          RED / YELLOW          (+)          AT VEHICLE LIGHT SWITCH HARNESS
     Wipers-Lo          BLACK          (-)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          LIGHT GREEN/ RED          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Seat Mem 1          BROWN / LIGHT GREEN          (-)          AT SEAT MEMORY SWITCH
     Seat Mem 2          BLACK/ ORANGE          (-)          AT SEAT MEMORY SWITCH
     Remote Start
     Accessory 1          BLACK/ LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLACK/ PINK          (+)          IGNITION SWITCH HARNESS
     Neutral Safety          PINK/LIGHT GREEN          (-)          AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
               PIN #46
     Tachometer          TAN          (AC)          PCM MODULE ON PASSENGER SIDE FIREWALL
               PIN #52
     Crankshaft Sensor          GRAY          (-)          AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
               PIN #46
     Camshaft Sensor          DARK GREEN          (-)          AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
               PIN #45
     Speed Sense          GRAY/BLACK          (-)          AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
               PIN #63
     Brake Lights          GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          BLACK/ PINK          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          DARK BLUE          (-)          IN HARNESS AT STEERING COLUMN
     Anti Theft RX          GRAY/ORANGE
     Anti Theft TX          WHITE/ LIGHT GREEN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          PINK/GREEN          (-)          AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
               PIN #1
     PowerLock          PINK / YELLOW          (-)          AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
               PIN #9
     Driver Mtr Unlock          RED / ORANGE          (AC)          AT MOTOR IN DOOR
     Driver Mtr Lock          PINK/BLACK          (AC)          AT MOTOR IN DOOR
     Pas Mtr Unlock          PINK/ORANGE          (AC)          AT MOTOR IN DOOR
     Pas Mtr Lock          PINK/BLACK          (AC)          AT MOTOR IN DOOR
     LF Window Up          TAN/LIGHT BLUE          (REV)          AT DRIVER WINDOW CONTROL SWITCH
     LF Window Dn          WHITE/ BLACK          (REV)          AT DRIVER WINDOW CONTROL SWITCH
     RF Window Up          TAN/LIGHT BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RF Window Dn          WHITE/ YELLOW          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
mobile1
Silver - Posts: 479
Posted: February 07, 2008 at 8:20 AM / IP Logged
The audiovox sheet lists locks at the BCM, but you should also be able to find them coming through the driver's door boot. Might be easier than running wire to the BCM.
