ke 30 locking issue
vosmith
Member - Posts: 7
Posted: March 15, 2008 at 4:44 PM / IP Logged
Ok so after i hooked up my wires as well as I saw fit i tested it out. Turns out if i lock the driver side door, the other doors will lock with it and then immediately unlock. I tested the remote and the same thing happens, the doors lock and then immediately unlock. Any ideas about this one?
-this isn't as easy as I thought
brhaugen
Copper - Posts: 275
Posted: March 17, 2008 at 4:25 PM / IP Logged
you will have to give us a little more info - what vehicle are you installing??? Thanks
chadwa2003
Copper - Posts: 353
Posted: March 17, 2008 at 8:51 PM / IP Logged
Are you testing with the door open?
vosmith
Member - Posts: 7
Posted: March 19, 2008 at 2:25 PM / IP Logged
Hey sorry guys, i figured out what my problem was. I the push rod on the 5 wire actuator on my front passenger door wasn't moving enough to trigger that motor to fully lock. So it would send its own signal back telling the other doors to unlock too. If anyone else is installing power locks in a 4-door sedan, i would suggest only using 1 5-wire actuator on the driver side door and 3 2-wire actuators for the others. So power locks-done, keyless-done. All i gotta do is replace my head unit and I'll be one happy camper....pretty sure i can do this without a major screwup. I appreciate everyone's help!
