wire diagram for a 2002 chry voyager?
mobileinstallat
Copper - Posts: 92
Posted: March 02, 2003 at 2:18 PM / IP Logged
any tips on this one is appr, just doing a basic remote start. My notes tell me I need to GROUND! a second start wire (purp/brown)using a 180ohm resistor? using a relay to isolate it from the remote starter module. and also I only need ign1 connected nothing else? accurate?
if anyone has a wire diagram that you used already please let me know.
Thank you men,
Mark
the12volt
Administrator - Posts: 3,959
Posted: March 02, 2003 at 3:07 PM / IP Logged
Here's what I have for a 2002 Voyager
|       ITEM      |     WIRE COLOR |POL|       WIRE LOCATION    |
|              12V|lt blue/red (10A) *1|+  |ignition harness    |
|          STARTER|yellow          |+  |ignition harness        |
|   SECOND STARTER|PURPLE / brown *12|-  |ignition harness        |
|         IGNITION|pink/white      |+  |ignition harness        |
|        ACCESSORY|*11             |   |                        |
|       POWER LOCK|PURPLE / green *3 |-  |conn. 3, pin 21 @ BCM *2|
|     POWER UNLOCK|same wire       |   |                        |
|       LOCK MOTOR|tan/white       |   |conn. 2, pin 10 @ BCM *2|
|     UNLOCK MOTOR|tan/lt. green   |   |conn. 2, pin 28 @ BCM *2|
|    DISARM DEFEAT|tan/brown       |   |conn. 2, pin 26 @ BCM *2|
| PARKING LIGHTS +|DO NOT USE      |   |                        |
| PARKING LIGHTS -|WHITE/ brown *8  |   |headlight switch        |
|       HEADLIGHTS|same wire       |   |                        |
|     DOOR TRIGGER|*4              |-  |BCM *2                  |
| DOME SUPERVISION|use door trigger|   |                        |
|  TRUNK/HATCH PIN|PURPLE / orange *9|-  |conn. 3, pin 29 @ BCM *2|
|         HOOD PIN|PURPLE / lt. blue |-  |conn. 3, pin 30 @ BCM *2|
|TRNK/HTCH RELEASE|*10             |   |*10                     |
|  FCTRY ALARM ARM|PURPLE / lt. blue |*5 |conn. 3, pin 14 @ BCM *2|
|FCTRY ALRM DISARM|same wire       |   |                        |
|       TACHOMETER|*6              |   |ignition coil pack      |
|      SPEED SENSE|blue/orange     |   |PCM *7                  |
|       BRAKE WIRE|WHITE/ tan       |+  |brake pedal switch      |
|     HORN TRIGGER|GREEN/ purple    |-  |steering column         |
|           WIPERS|brn/wht & brn/org   |+  |wiper motor             |
|  LF WINDOW UP/DN|org/lt grn - org/wht|A  |drivers window switch   |
|  RF WINDOW UP/DN|org/tan - org/gry   |A  |drivers kick panel      |
|  LR WINDOW UP/DN|org/blu - org/lt blu|A  |drivers kick panel      |
|  RR WINDOW UP/DN|org/gry - org/grn   |A  |drivers kick panel      |
|        RADIO 12V|gray/red        |+  |radio                   |
|     RADIO GROUND|                |   |                        |
|     RADIO SWITCH|blue/pink       |+  |radio                   |
| RADIO ILLUMINATE|ORANGE / tan      |+  |radio                   |
|       LF SPEAKER|green - grn/brn |   |radio                   |
|       RF SPEAKER|gray - gray/brn |   |radio                   |
|       LR SPEAKER|grn/blu - grn/org   |   |radio                   |
|       RR SPEAKER|gry/blu - gry/org   |   |radio                   |
Notes:NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v. *2 The BCM is in the drivers kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs. *3 Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays. *4 There are separate door triggers for each door, they are all in connector 3 at the BCM. The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information. *5 Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays. *6 On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan or blue/orange. *7 The PCM is behind the driver side headlight. VSS is in the gray plug, pin 66. *8 The parking lights are negative trigger thru a 2.1K ohm resistor. The headlights are negative trigger thru a 790 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information. *9 A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights. *10 Hatch release is PURPLE / tan in connector 2, pin 6 at the BCM. It is negative trigger thru a 1.69K ohm resistor. Left power sliding door is PURPLE / blue in connector 3, pin 1 at the BCM. It is negative trigger thru a 1.5K ohm resistor. Right power sliding door is the same wire as the left and it is negative trigger thru a 2.7K ohm resistor. Must use relays. *11 Accessory is not required for remote start. *12 The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information.
wire diagram for a 2002 chry voyager? -- posted image. the12volt • Support the12volt.com
