bench test viper 5900?
gottspeed
Member - Posts: 13
Posted: March 16, 2008 at 8:54 AM / IP Logged
Can I hook up the module 12v to the battery and ground the other required wires to bench test this unit? I have to figure out if its fried...
Is it as simple as putting the module 12v on the positive battery terminal and the ground on the negative? That should produce an LED blink right?
brhaugen
Copper - Posts: 275
Posted: March 16, 2008 at 8:58 AM / IP Logged
one thread per issue please -
Twelvoltz
Platinum - Posts: 2,384
Posted: March 16, 2008 at 9:01 AM / IP Logged
If you are looking to just test if the unit responds then you could just hook up the constant and ground inputs, as well as the antenna and the LED to see if it blinks when you press arm and stops blinking when you press disarm. To do a test that would be a little more thorough you would need to hook up a siren, something to simulate the parking lights, and use the positive and negative from your battery to test the instant trigger inputs.
gottspeed
Member - Posts: 13
Posted: March 16, 2008 at 9:03 AM / IP Logged
Thanks, and sorry for the double thread.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
