2007 nissan titan crew cab
slwilson6
Member - Posts: 6
Posted: March 25, 2008 at 4:06 PM / IP Logged
anyone have a wiring diagram for alarm remote start and windows?
i have the 2006 wiring diagram...any idea if there are any changes?
teeb
KarTuneMan
Platinum - Posts: 7,056
Posted: March 25, 2008 at 11:28 PM / IP Logged
This is an 07
PASSIVE ANTI-THEFT
YES
TRANSPONDER
SEE NOTES
 12 VOLTS Green Ignition Harness   +
 IGNITION BLACK/ Red Ignition Harness   +
 ACCESSORY Red Ignition Harness   +
 STARTER Brown Ignition Harness   +
 STARTER 2 Lt.Green Ignition Harness   +
 KEY SENSE RED / blue Ignition switch harness   +
 TACH SIGNAL SEE NOTES    AC
 This vehicle has independent coils, there are three wires per coil, WHITE/ Blue, Black and the third is the tach signal wire.
 FUEL INJECTOR Opposite of White At any injector on engine   AC
 LOCK Blue At switch inside driver's door   -
 You must run wires into the doors to connect to these wires. The first pulse on the RED will disarm and a double pulse will unlock the doors.
 UNLOCK Red At switch inside driver's door   -
 DOORPIN SEE NOTES
 Driver's door is LT.BLUE, front passenger door is RED / BLUE. The left rear door is RED / YELLOW and the right rear door is RED / WHITE. All 4 wires are (-) and found at the BCM on the right side of the steering column.
 R.A.P. SHUT DOWN Lt.Blue SEE NOTES   -
 This vehicle is equipped with automatic headlights that will stay on after a remote shutdown.you must pulse the drivers doorpin wire to shut the lights off. Drivers doorpin is Lt.Blue at BCM on right side of steering column.
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH RED / Green At brake switch   +
 PARKLIGHTS RED / Blue At dimmer switch   +
 HAND BRAKE Green At switch on handbrake lever   -
 HORN RED / White At steering column harness   -
 VSS WIRE WHITE/ red Behind instrument panel   AC
slwilson6
Member - Posts: 6
Posted: March 26, 2008 at 7:21 AM / IP Logged
thanks.
teeb
