newbie, 96 mazda 626, keyless
htorvisque
Posted: April 13, 2008 at 8:27 AM / IP Logged
Hi,
I have bought a keyless entry system on ebay for my 96 mazda 626. I fell for the "easy fit!" "anyone can do it!" stuff and now feel out of my depth and silly.
The 'instructions' were actually just a cryptic wiring diagram in mangled English making reference to negative triggers and positive triggers. How do I know what kind of trigger I have? :-)
All of the wiring diagrams I've looked up on the net have mentioned that for my Mazda 626 I need to add an actuator to the driver's door. Actually, I don't think I do. I've tested locking the car from the passenger door and all locks work.
So basically, any help on where I go from here would be MUCH appreciated.
I can scan the 'instructions' I got but I'd love some specific help - where things are, what type of wire taps I should use, where I should fit the damn thing...
And if it's even as complicated as it's made out! I've read on other forums I need only to connect ground, and to splice into the drivers footwell two wires coming from the driver's door harness!
THANKS GUYS!
htorvisque
Posted: April 13, 2008 at 8:29 AM / IP Logged
and if I'd get more replies in another sub-forum...please feel free to move it!
KarTuneMan
Platinum - Posts: 7,056
Posted: April 13, 2008 at 1:44 PM / IP Logged
do you have a lock/unlock button on the door by the power window switch? If you do, then you do not need an actuator. If you don't....you need the actuator.
My notes say you NEED the actuator. It's needed to move the lock tab on the inside of the door.  Pull the door panal and you'll see.
Here is one look at it    And YOUTUBE is good too. Mount it so the unit can move free and easy.
Wire the relay like this
newbie, 96 mazda 626, keyless -- posted image.
htorvisque
Posted: April 13, 2008 at 5:24 PM / IP Logged
I don't have a lock/unlock button on the door - but why would I need an actuator when that door already has an actuator in it?
Bear in mind this is a European car so may be different to the car you're thinking of.
Unfortunately your diagram is pitched over my head.
Basically I have a control box with a whole load of wires coming out of it. I know that I have to splice these into existing wires but I don't know how to get at these wires etc...
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
