using cat5 to wire sensors
pepebuho
Member - Posts: 8
Posted: April 13, 2008 at 9:52 AM / IP Logged
Hi
I wonder about using CAT 5 wire to hook a sensor to my alarm (Viper 5002). The sensor is a movement sensor, Crimestopper AU94T which I am placing on the roof of a SUV. The wire with the sensor is AWG22, CAT5 is usually AWG24.
I do not think this sensor handles that much of a current.
What do people think of it?
Illegitimi Non Carborundum
Platinum - Posts: 13,723
Posted: April 13, 2008 at 10:12 AM / IP Logged
I am not going to say the ONLY problem with using Cat5 or any other non-stranded type of wire is a reliability issue.  But that is at least one problem.  The wire as you know is a single conductor.  In an environment such as an automobile, it is subjected to a lot of vibration and flexing.  This is generally not a problem for the wire still inside of the jacket.  But once the jacket is stripped off of it the individual wires are allowed to move around a good bit.  The solid wire will break over time.  Just double up or triple up on the power and ground connections and use the remaining 2 conductors for the trigger wire. This way if 1 wire does break, the other or others will keep you working.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 13, 2008 at 1:18 PM / IP Logged
If you have it layin around....sure why not. But as idiot said, secure it well. If you need to purchase wire to do the job, don't spend it on CAT5.
Spend it on multistrand wire, the wire that should be used.
pepebuho
Member - Posts: 8
Posted: April 14, 2008 at 3:33 AM / IP Logged
Thanks!
The problem with multistrand wire is that at least on my country it is hard to come by. Anything with more than two wires becomes quite difficult to find out, specially at such small AWGs like 14+
JP
chriswallace187
Gold - Posts: 1,661
Posted: April 14, 2008 at 4:18 AM / IP Logged
pepebuho,
Parts Express website says they'll ship to Panama with a $50 minimum order - you might want to look at that option.
C Renner's Auto Electronix
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
