bypass kit, 1997 buick lesabre
eric3337
Member - Posts: 9
Posted: April 13, 2008 at 5:42 PM / IP Logged
I am installing a remote start on a 1997 Buick LeSabre.  I was told that there is not a bypass kit needed for this car but the key has a chip in it.  Do I need a bypass kit or do I need to use a resistor to bypass and how do I bypass with the resistor.  Thank you for your help in advance.
dtk1
Copper - Posts: 179
Posted: April 13, 2008 at 7:49 PM / IP Logged
take your volt metter measure the resistance on the key and a realy thats all you need let me see if i can find you a diagram
dtk1
Copper - Posts: 179
Posted: April 13, 2008 at 7:53 PM / IP Logged
here you go http://documents.audiovox.com/700052.pdf
surfboss
Posted: May 14, 2008 at 3:37 AM / IP Logged
eric and dtk1, I hope you don't mind my hijacking this thread but I'm having starting problems with my 97 Riviera.
Your diagram shows pins 85 and 86 wired thru a remote source but I'm wondering if this couldn't work by taking constant 12v+ and ign return directly from the switch on the column and start by turning the key?   I am not in favor of having an extra fob or push button to start the engine. I will appreciate any input you can provide.
techman93
Silver - Posts: 591
Posted: May 14, 2008 at 10:55 PM / IP Logged
eric:
The relay and resistor is all you need for that vehicle with VATS.
surfboss:
I think you need to know what is causing the starting issue either it is mechanical or electrical. You should diagnose what the real problem is. The anti theft or something in the ignition system could be faulty or the starter itself has a dead spot and you need a new starter motor.
I would have a mechanic check the starter to eliminate each aspect of the mechanical reasons why it wont operate then test the electrical aspect. I would clean the chip on the key with rubbing alcohol to clean the contacts and check resistance to be sure your getting a good value. I would even call a dealer with your vin and have then make you a new key if the key is old and worn out.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
