07 xterra x's wiring diagram for alarm
wyciwug
Copper - Posts: 158
Posted: April 22, 2008 at 12:43 PM / IP Logged
i am looking for diagram for 07 Xterra for Alarm.  I saw the diagram for 2005 xterra but I think the door trigger wiring is not correct.  It said:
Door Trigger see notes   -   BCM
Notes: The LF door is gray in pin 47. The RF door is lt. green in pin 12. The LR door is pink in pin 48. The RR door is blue in pin 13. Use all four wires and diode isolate each.
Now, how do I know which blue color is Pin #13, which gray is Pin 47 and so on because there are so many plugs there at the BCM?  Or just ignore the number and use a test light instead?
Thank for helping.
dcd
wyciwug
Copper - Posts: 158
Posted: April 22, 2008 at 12:45 PM / IP Logged
Please ignore the second sentence on my first paragraph.  Thanks.
dcd
eclipse_420
Posted: April 22, 2008 at 10:03 PM / IP Logged
12 Voltsgreen (40A)+ignition harness
Startergray+ignition harness
IgnitionWHITE/ green+ignition harness
Can Bus Highbluedatadata link connector under driver dash, pin 6
Also found at the BCM, pin 39. The security light wire is green (-) at the instrument cluster or the BCM, pin 23. The BCM (Body Control Module) is to the right of the steering column.
Can Bus Lowpinkdatadata link connector under driver dash, pin 14
Also found at the BCM, pin 40. The BCM (Body Control Module) is to the right of the steering column.
Power Locklt. green to purple-driver kick or BCM, pin 45
Power Unlockwhite to lt. green-driver kick or BCM, pin 46
Parking Lights (+)gray+driver kick, harness to rear
SOMETIMES IF YOU CATCH JUST ONE OF THE DOOR TRIGGER WIRES IT WILL TRIGGER WITH ANY DOOR.  IT WOULD BE WORTH CHECKING IT WILL SAVE YOU ALOT OF WORK.
Left Front Door Triggergray-driver kick or BCM, pin 47
The BCM (Body Control Module) is to the right of the steering column. On vehicles without power door locks, the driver door trigger is blue in the driver kick panel.
Right Front Door Triggerlt. green-passenger kick or BCM, pin 12
The BCM (Body Control Module) is to the right of the steering column. On vehicles without power door locks, the passenger(s) door trigger is red in the passenger kick panel.
Left Rear Door Triggerpink-driver kick or BCM, pin 48
Right Rear Door Triggerblue-passenger kick or BCM, pin 13
Dome Supervisionbrown-driver A pillar or BCM, pin 63
Factory Alarm Armlt. blue-driver kick or BCM, pin 8
Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors. The BCM (Body Control Module) is to the right of the steering column.
Factory Alarm DisarmRED / white to gray-driver kick or BCM, pin
