remote starter, 97 chevrolet siverado
popeye004
Copper - Posts: 97
Posted: April 25, 2008 at 5:51 PM / IP Logged
HI guys I have a 97 chevy pickup siverado and a hornet remote started and alarm combo. When I hit the start button on my truck's remote it does not start however I hear the fuel injecter and all the lights and ACC comes on just does not crank. I had this system in the truck since 1999 (i know its old :)HAHA) and it was working fine but then about a year ago it just died all the sudden. so can it be some sort of resister in my start wire that went bad or what can it be? any help will be greatly appreciated.
Moderator - Posts: 12,488
Posted: April 25, 2008 at 11:37 PM / IP Logged
Check the starter out put to the starter wire and see if it's outputting 12 volts when starting.
popeye004
Copper - Posts: 97
Posted: April 26, 2008 at 12:23 AM / IP Logged
You mean the starter output wire on the main unit (the brain or remote starter). and I presume that it will only be 12 volts when it is attemting to start?
Posted: April 26, 2008 at 8:35 AM / IP Logged
Yes, it will have 12 volts when the RS cranks. Check before and after the anti-grind starter ( if installed)
chriswallace187
Gold - Posts: 1,661
Posted: April 29, 2008 at 1:13 AM / IP Logged
popeye, I'm also going to guess that your system has 4 external relays for the remote start? If that's the case you could try swapping the starter relay with the accessory one and see if it works - if it does just replace the relay.
C Renner's Auto Electronix
popeye004
Copper - Posts: 97
Posted: April 29, 2008 at 2:21 AM / IP Logged
I think I do have 3 or 4 relays all taped together. Is it just the regular relay kinda like the with the SPDT and SPST Automotive Relays Like this. I haven't got to it yet just so busy writing a program, but I will try to tackle it tommorow.
chriswallace187
Gold - Posts: 1,661
Posted: April 29, 2008 at 1:06 PM / IP Logged
Exactly that type...they would probably not be taped, but there would be 4 harness connectors for them which lock together. I'm not sure when DEI originally started making their remote starts like that but I know they were still making those in late 2002, so I'd assume yours is a similar design.
popeye004
Copper - Posts: 97
Posted: April 29, 2008 at 2:05 PM / IP Logged
OK I'll accually go and check that out and I will also try what Velocity told me to do thanks alot.
popeye004
Copper - Posts: 97
Posted: April 29, 2008 at 4:40 PM / IP Logged
Here is the manual for my starter but what is the starter output wire http://www.directed.com/guides/manuals/ig/hornet/N553T.pdf
tedmond
Gold - Posts: 4,610
Posted: April 29, 2008 at 8:32 PM / IP Logged
the starter wire is the purple wire.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
