wiring diagram 95 Taurus
joeshwetz
Posted: March 05, 2003 at 8:39 AM / IP Logged
  Need wiring diagram for a 1995 Ford Taurus Sedan  3.0 L  V6   to install a remote starter kit ??
Mr. Joe
10nesne1
Silver - Posts: 284
Posted: March 05, 2003 at 9:45 AM / IP Logged
YEAR: 1995 MAKE: Ford MODEL: Taurus STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V |yellow               | + |ignition harness            |
|             STARTER |WHITE/ pink           | + |ignition harness            |
|            IGNITION |RED / lt. green        | + |ignition harness            |
|           ACCESSORY |gray / YELLOW          | + |ignition harness            |
|    SECOND ACCESSORY |BLACK/ green          |    |ignition harness            |
|          POWER LOCK |pink / YELLOW          | *2 |either kick                 |
|        POWER UNLOCK |pink/green           | *2 |either kick                 |
|          LOCK MOTOR |pink/black           |    |drivers door harness        |
|        UNLOCK MOTOR |RED / orange           |    |drivers door harness        |
|       DISARM DEFEAT |pink/orange          |    |passengers door harness     |
|    PARKING LIGHTS + |brown               |    |headlight switch            |
|          HEADLIGHTS |RED / yellow           | + |headlight switch            |
|        DOOR TRIGGER |BLACK/ blue           | + |either kick                 |
|    DOME SUPERVISION |use door trigger     |    |                            |
|     TRUNK/HATCH PIN |                     |    |                            |
| TRUNK/HATCH RELEASE |gray/red             | + |at release switch           |
|          TACHOMETER |tan / YELLOW *1        |    |ignition coil *1            |
|          BRAKE WIRE |RED / lt. green        | + |at brake switch             |
|        HORN TRIGGER |yellow/lt. green     | - |steering column             |
|              WIPERS |BLACK/ pink           | + |at switch                   |
|   LF WINDOW UP/DOWN |yellow - red        | A |drivers door switch        |
|   RF WINDOW UP/DOWN |yel/blk - RED / blk    | A |drivers door harness        |
|   LR WINDOW UP/DOWN |yel/blu - RED / blu    | A |drivers door harness        |
|   RR WINDOW UP/DOWN |yel/blk - RED / blk    | A |drivers door harness        |
NOTES:
*1 For multi-coil engines the tach is gray/orange at the DIS module on the
pass side of motor.
*2 Five-wire for non-keyless, negative-pulse for the keyless versions.
