2000 nissan maxima remote start
Cbr629
Copper - Posts: 79
Posted: May 14, 2008 at 8:34 AM / IP Logged
I want to install a Omega brand remote starter and a local installer says I need to program the keys to make it work,is there any by-pass I can use without programing the keys?
thanks
dtk1
Copper - Posts: 179
Posted: May 14, 2008 at 9:22 AM / IP Logged
you would need to give up a key if you want a remote start those are first generation Nissan immobilizer
Cbr629
Copper - Posts: 79
Posted: May 15, 2008 at 9:10 AM / IP Logged
Ok,so after I give up the key and I get a locksmith to my another one how with it work? Isn't the keys programmed different? Will any of the by pass systems still start the car?
thanks
dtk1
Copper - Posts: 179
Posted: May 15, 2008 at 9:44 AM / IP Logged
ok this is how it is you give up the key the installer you put it in a box and hide it somewhere inside the dash that way when you remote start the car the car sees the key and allow the car to start read the immobilizer topic that would help you understand a little bit more
KarTuneMan
Platinum - Posts: 7,056
Posted: May 15, 2008 at 11:19 AM / IP Logged
If you need/want more keys for your Max. you can only get them programmed at the dealer.
ps. hang on to your wallet!
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
