Anything i should know on a Lexus RX300
par3721
Member - Posts: 26
Posted: March 06, 2003 at 1:58 AM / IP Logged
A lady wants me to install either a viper remote start or a python remote start (samething)on i believe it is a 1997 Lexus RX300. not sure if the year is correct. but i wanted to see if there is anything i need to know before i start, or will it be like installing on a toyota? if it is a '97 or a '98 i need the wiring diagram ( i only found '99 here).
thanks in advance
Bnluis
Silver - Posts: 578
Posted: March 06, 2003 at 12:23 PM / IP Logged
98 Lexus Rx300
|              12V|WHITE/ blue          |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|black               |+  |ignition harness            |
|        ACCESSORY|pink                |+  |ignition harness            |
|       POWER LOCK|see direct fax      |   |                            |
|     POWER UNLOCK|document # 1070     |   |                            |
| PARKING LIGHTS +|green               |   |drivers kick panel *1       |
| PARKING LIGHTS -|GREEN/ red           |   |steering column             |
|       HEADLIGHTS|RED / blue            |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |steering column *2          |
| DOME SUPERVISION|same as doors       |   |                            |
|  TRUNK/HATCH PIN|WHITE/ red           |-  |drivers kick *3             |
|         HOOD PIN|RED / blue            |-  |*4                          |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blue/silver dots *7 |-  |steering column             |
|       TACHOMETER|orange              |   |right of the fuse box *5    |
|      SPEED SENSE|violet/white        |   |*6                          |
|       BRAKE WIRE|GREEN / WHITE         |+  |at switch                   |
|     HORN TRIGGER|WHITE/ red           |-  |steering column             |
|           WIPERS|blue/blk - blue/red |+  |steering column             |
|  LF WINDOW UP/DN|red   -   green     |A  |in door at motor            |
|  RF WINDOW UP/DN|red   -   green     |A  |in door at motor            |
|  LR WINDOW UP/DN|red   -   green     |A  |in door at motor            |
|  RR WINDOW UP/DN|red   -   green     |A  |in door at motor            |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|   SUN ROOF LIMIT|not recommended     |   |                            |
|        RADIO 12V|WHITE/ blue          |+  |at radio                    |
|     RADIO GROUND|brown               |-  |at radio                    |
|     RADIO SWITCH|gray/red            |+  |at radio                    |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|black               |+  |at radio                    |
|       LF SPEAKER|pink   -   purple   |   |at speaker or amp *8        |
|       RF SPEAKER|lt.green   -   blue |   |at speaker or amp *8        |
|       LR SPEAKER|black   -   yellow  |   |at speaker or amp *8        |
|       RR SPEAKER|red   -   white     |   |at speaker or amp *8        |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U or 555F.  *1  Located in a gray 15 pin plug.  *2  This wire goes to the key cylinder illumination ring and reads the delay.   *3  Located in a 20-pin plug, low in the kick panel.  Test only with a digital multi-meter as some of the multiplex wires in the car are WHITE/ red.  *4  In the engine compartment, under the relay box on the drivers side in a gray 17-pin plug, pin #1  *5  In a 10-pin plug.  *6  Coming from the cluster to the cruise control computer, it is located just above the drivers main fuse/relay box.  *7 This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.  *8 The amplifier is under the rear seat.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
mxxmikexx
Silver - Posts: 796
Posted: March 06, 2003 at 3:30 PM / IP Logged
yeah, theres a crazy doorlock/factory security interface you need to do in the drivers door, with 3 wires, a relay, and diodes. and also the autolights will stay on after the starter shuts off, so you need to pulse a doortrigger to shut off the lights after the starter shuts down. if you want a copy of the diagram email me and ill send it to you
Mike
specialized car audio
chicago illinois
