03 volvo s60
mxxmikexx
Silver - Posts: 796
Posted: March 06, 2003 at 3:12 PM / IP Logged
has anyone done a remote start on this car that can offer me some pointers? my audiovox tech program says that the factory security is RF controlled, so can you do a remote start on this car without the factory alarm going off when you start it? thanks
Bnluis
Silver - Posts: 578
Posted: March 07, 2003 at 9:17 AM / IP Logged
I've done 2 of them. Car starts fine , don't worry so much of factory alarm it will disarm as soon as it sees ignition. or follow instruction below, Also you will have to go to battery for 12volts, do not use the wire at the ignition, it has a very low current. One more thing you should know both car I did the airbag light went on, I tried to find out what the problem was, all my connections were fine, I have heard that you have to power the Second ignition as a Key sense wire (remember is a positive) not as ignition meaning it has to see this wire on before it sees ignition, use one of the wires you will be using for your transponder bypass. One more thing the wires at the ignition are very small gauge. I really think this car is a pain in the **s, it is already in my list, I won't do any more New Volvos, but good luck.
P.S. the trnsponder in the key is very sensitive, make sure you mount it prperlly, or you will hear from custumer that the car only starts with remote after car has been running for a while. Letme know how it works for you.
|              12V|RED / black   (10A) *7|+  |ignition harness            |
|          STARTER|yellow/white        |+  |ignition harness            |
|         IGNITION|blue/red            |+  |ignition harness            |
|  SECOND IGNITION|yellow (key sense)  |+  |ignition harness            |
|        ACCESSORY|purple              |+  |ignition harness            |
|       POWER LOCK|PURPLE / white        |-  |drivers door module *2      |
|     POWER UNLOCK|blue/white          |-  |drivers door module *2      |
|       LOCK MOTOR|yellow              |   |drivers door module         |
|     UNLOCK MOTOR|gray                |   |drivers door module         |
|    DISARM DEFEAT|gray                |   |drivers rear door harness   |
| PARKING LIGHTS +|white               |   |fuse box                    |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|pink                |-  |each door harness *4        |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|BROWN / orange        |-  |trunk pin switch *5         |
|         HOOD PIN|yellow              |-  |hood pin switch             |
|TRNK/HTCH RELEASE|gray/white          |5wi|in trunk *6                 |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*3                  |   |                            |
|       TACHOMETER|*1                  |   |ignition coil               |
|       BRAKE WIRE|yellow              |+  |brake switch                |
|     HORN TRIGGER|yellow              |-  |central electronic module   |
|           WIPERS|blue and yellow     |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / black - purple  |A  |LF window switch            |
|  RF WINDOW UP/DN|RED / black - purple  |A  |RF window switch            |
|  LR WINDOW UP/DN|RED / black - purple  |A  |LR window switch            |
|  RR WINDOW UP/DN|RED / black - purple  |A  |RR window switch            |
|        RADIO 12V|red                 |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|purple              |+  |radio                       |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|gry/red - gray      |   |radio                       |
|       RF SPEAKER|gry/red - gray      |   |radio                       |
|       LR SPEAKER|gry/wht - gray      |   |radio                       |
|       RR SPEAKER|gry/wht - gray      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U.  *1 Use any of the following;  blue, brown, yellow, pink, purple, or gray.  *2 These are the drivers door key cylinder wires, meter by turning the key in the door. Unlock requires a double pulse.  *3 A single pulse on the unlock wire will disarm the factory alarm without unlocking the doors.  *4 There is pink wire for each of the 4 doors. Use all of them and diode isolate. All four wires can also be found at the central electronic module under the driver side dash in three separate plugs.  *5 Also found pink at the central electronic module.  *6 In a white plug behind the driver side taillight.  *7 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
jrilla
Gold - Posts: 1,498
Posted: March 07, 2003 at 10:05 AM / IP Logged
BnLuis, email me your "List" if you get a chance. I am just curious.
J Rilla
Owner/Installer
mxxmikexx
Silver - Posts: 796
Posted: March 07, 2003 at 10:38 AM / IP Logged
yeah, this is a "friend of a friend" deal so i cant even charge full price, and if its gonna be a car im gonna marry, or be a huge pain in the as#, i think im better off just letting this one pass.
jrilla
Gold - Posts: 1,498
Posted: March 07, 2003 at 11:19 AM / IP Logged
For sure, they can afford to go to a shop, so let someone else deal with the headache.
J Rilla
Owner/Installer
RufNUSD
Copper - Posts: 184
Posted: March 07, 2003 at 9:42 PM / IP Logged
Bnluis it sounds as though to me that you dont like work. How hard is it to energize a relay for key sense? Second, I havent heard of a 555U being sensitive to the vehicle being started prior. Maybe you should revisit the basics? Running a power wire to the battery for constant...what a noble concept and a way to make more money on your installs? If you explain why it costs more and sell yourself then it should all be uphill for you from there. Prost, Mel
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
