relay flasher problem
matthew9440
Posted: July 01, 2008 at 3:18 AM / IP Logged
Hey,
I have a remote central locking kit, that has no light flash output, and I wanted to add a light flash relay setup that would flash once for unlock, and twice for lock or vice versa.
I have checked the wires and have one wire that pulses positive when unlocked and another that will flash positive when locked. So with either one I can make a single flash no problems, but its making the other cause the indicator lamps to flash twice.
I havent seen any off the shelf relay that will allow me to do it, any ideas on wiring that up?
thanks all.
Posted: July 02, 2008 at 3:58 PM / IP Logged
Use it to feed atimer device, that will at least give you a longer pulse for one of the outputs.
