2009 nissan murano, doorlocks
mobilefx
Copper - Posts: 48
Posted: July 24, 2008 at 12:51 PM / IP Logged
doin a new murano.. not really fun,  tech is limited and mostly crossover from newer altima.  sick of calling tech cuz they are rude.. you tell them they are wrong and they hang up..
anywhooo, need to get doorlocks.  i am thinking you can insert into bcm however have no pin locations..
anyone know?  asap?  thanks
mobile f/x
kola7126
Copper - Posts: 93
Posted: July 24, 2008 at 1:55 PM / IP Logged
MURANO  2008 -
POWER LOCK BLUE(-)TYPE "B"  AT MODULE INSIDE DRIVERS DOOR
 POWER UNLOCK RED (-)TYPE "B" REQUIRES DOUBLE PULSE UNLOCK  AT MODULE INSIDE DRIVERS DOOR
KPierson
Platinum - Posts: 3,527
Posted: July 24, 2008 at 4:12 PM / IP Logged
You should be able to five wire the door locks as well at the BCM - can usually pick out the wires because they are thicker then the rest.  If you need OEM disarm you'll need to go in to the doors, though.
Kevin Pierson
