04 accord factory alarm wires
fuzzuy
Posted: July 31, 2008 at 1:02 PM / IP Logged
Hello,
I have installed the remote starter in my 04 accord no problem, and i do understand that i need to hook up factory arm and disarm wires to white and to WHITE/ red in drivers door module in order to do that i have to fish wire through the door ?? or is there any other way or color of wires comming to driver kick pannel so there i can hook up let me know pls and thank you.
Platinum - Posts: 13,723
Posted: July 31, 2008 at 8:46 PM / IP Logged
All of the info I have found says it is in the door.
twistedp
Member - Posts: 38
Posted: July 31, 2008 at 10:46 PM / IP Logged
you must tag in the door and run the wires through the boot. no other way, sorry.
Twisted Performance
moonliter
Copper - Posts: 322
Posted: July 31, 2008 at 11:41 PM / IP Logged
If you have used a can-sl2, you wouldn't have to tap into the door.
fuzzuy
Posted: August 06, 2008 at 3:02 PM / IP Logged
Hello,
Ok so i run the wires through the door now where do i see white and WHITE/ red wires in the door as i try connecting the white and WHITE/ red wire to which is going out from the central white plug where the windows controls does not work still the same i try connecting white in the same plug and WHITE/ red in the small connecto result is the same so now my questions is there where are those WHITE and WHITE/ RED wires which i taped on for arming and disarming my factory alarm from the remote starter thanks in advance.
chillin420
Copper - Posts: 236
Posted: August 06, 2008 at 3:57 PM / IP Logged
have you metered the wires as you lock and unlock  from the door lock switch?
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
KPierson
Platinum - Posts: 3,527
Posted: August 06, 2008 at 3:59 PM / IP Logged
You need to find these with a volt meter.  You can meter them by turning the key in the drivers door to the lock and unlock positions.  They should read 5vdc until you turn the key to the respective position, then that voltage should drop to 0vdc.
The Hondas have lots of WHITE/ red wires in the door - one of which I believe is a constant 12vdc wire that will burn things up quickly when (-) outputs are tied to it.
Kevin Pierson
jmsounds
Copper - Posts: 99
Posted: August 06, 2008 at 4:17 PM / IP Logged
just follow the wires that goes to the key cylinder in the door
megaman
Copper - Posts: 385
Posted: August 06, 2008 at 4:38 PM / IP Logged
Don't follow wires.... TEST with a Multimeter.
knightrider2000
Member - Posts: 15
Posted: August 07, 2008 at 1:49 PM / IP Logged
Im having this Same issue, How did you get them through the boot, did the boot just pull off?   Did you find the wires to tap into? I have a 2003 Accord coupe.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
