2000 Range Rover Diagram Request
prelude1481
Member - Posts: 16
Posted: March 10, 2003 at 7:31 AM / IP Logged
I am looking for a wiring diagram for a 2000 Land Rover Range Rover. I need a little more help that what is given in the wiring diagram listed on this site. Any help is greatly appreciated.
Thanks,
Jeremy
crxbumpin@aol.com
Bnluis
Silver - Posts: 578
Posted: March 10, 2003 at 9:45 AM / IP Logged
|              12V|                    |   |                            |
|          STARTER|WHITE/ red           |-  |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|white *1            |-  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|WHITE/ pink          |-  |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|yellow              |F  |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|                    |   |                            |
| PARKING LIGHTS -|ORANGE / red          |   |BCM under passenger seat    |
|       HEADLIGHTS|blue                |-  |BCM under passenger seat    |
|     DOOR TRIGGER|PURPLE / red          |-  |BCM under passenger seat    |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|purple / YELLOW       |-  |BCM under passenger seat    |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|white               |-  |at the switch               |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|blue                |-  |driver kick panel           |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|WHITE/ stripe        |   |ignition coil pack          |
|      SPEED SENSE|YELLOW /GREEN pin 11 |   |BCM under passenger seat    |
|       BRAKE WIRE|GREEN/ blue          |+  |brake pedal switch          |
|     HORN TRIGGER|PURPLE / brown        |-  |BCM under passenger seat    |
|           WIPERS|pink/lt green       |   |                            |
|  LF WINDOW UP/DN|gry/wht - gry/grn   |   |                            |
|  RF WINDOW UP/DN|gry/wht - gry/grn   |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
*1 To interface with the negative ignition wire to remote start, see directfax document #1500 for wiring information.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
prelude1481
Member - Posts: 16
Posted: March 10, 2003 at 8:19 PM / IP Logged
Thanks for what you posted but can you post directfax document #1500 so that I can see how do so such and also how will I work the single wire door lock systems, what does the "F" stand for in the polarity column?
Any help appreciated,
Jeremy
Bnluis
Silver - Posts: 578
Posted: March 11, 2003 at 2:11 PM / IP Logged
Type F is the type of door lock sysstem wire it this way, also follow the link for document 1500. Good luck.
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1500.pdf
2000 Range Rover Diagram Request -- posted image.
Luis
Sound Waves
