2008 chevrolet upland wiring diagram
caddyroger
Member - Posts: 6
Posted: October 15, 2008 at 7:05 PM / IP Logged
I need a 2008 checvrolet uplander wireing diagram so I can insta a alarm and remote start on it.
Caddy
Platinum - Posts: 13,725
Posted: October 15, 2008 at 10:03 PM / IP Logged
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSKEY III® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
     Tachometer          TAN          (AC)          AT PCM MODULE INSIDE AIR CLEANER ASSEMBLY
     Crankshaft Sensor          LIGHT BLUE/WHITE          (AC)          AT PCM MODULE UNDER AIR CLEANER UNDER HOOD
     Camshaft Sensor          BROWN / WHITE          (AC)          AT PCM MODULE UNDER AIR CLEANER UNDER HOOD
     Speed Sense          DARK GREEN          (AC)          RADIO HARNESS
     Parking Lights          BROWN / WHITE          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Brake Lights          WHITE          (+)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Reverse Lights          LIGHT GREEN          (+)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Horn          TAN          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Posted: October 15, 2008 at 10:05 PM / IP Logged
Above is Remote Start info. Following is info for alarm.
     Battery          RED          (+)          AT VEHICLE BATTERY
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/BLACK          (+)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Domelight Super          GRAY/BLACK          (+)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     LF Latch          GRAY/BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     RF Latch          TAN/WHITE          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     LR Latch          LIGHT BLUE/BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     RR Latch          LIGHT GREEN/ BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Trunk Trigger          DARK GREEN OR PINK/BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Hood Trigger          PINK/BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Alarm Disarm          LIGHT GREEN          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Alarm Arm          VIOLET          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Posted: October 15, 2008 at 10:06 PM / IP Logged
Door and Window info
     Power Unlock          ORANGE / BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     PowerLock          ORANGE / BLACK          (-)          AT BCM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
     Driver Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     Pas Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     LF Window Up          DARK BLUE          (REV)          AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          BROWN          (REV)          AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          LIGHT BLUE          (REV)          AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Dn          TAN          (REV)          AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Up          BROWN          (REV)          VEHICLE OVERHEAD CONSOLE
     LR Window Dn          TAN          (REV)          VEHICLE OVERHEAD CONSOLE
caddyroger
Member - Posts: 6
Posted: October 15, 2008 at 10:54 PM / IP Logged
Caddy
