98 grand am randomly stops running
rt4x4
Copper - Posts: 107
Posted: October 23, 2008 at 4:57 AM / IP Logged
I have a 98  grand am (passlock 1) with a viper 571xv and a 555l bypass kit randomly cause the car to stop running if the bypass kit is not working properly? This is even while driving the car and it hasnt been remote started
jmw505
Member - Posts: 46
Posted: October 23, 2008 at 6:47 AM / IP Logged
how long does it run before it shuts off
ckeeler
Gold - Posts: 1,461
Posted: October 23, 2008 at 9:17 AM / IP Logged
sounds as if you may have a bad connection on one of your ignition wires, or you may have a fuel pump problem(GM vehicles are famous for fuel pump issues).
chriswallace187
Gold - Posts: 1,661
Posted: October 25, 2008 at 1:13 AM / IP Logged
Just posted in another thread - you can be certain it's not a Passlock problem. Passlock will only cut off fuel during initial startup.
C Renner's Auto Electronix
rt4x4
Copper - Posts: 107
Posted: October 26, 2008 at 9:51 PM / IP Logged
I just wanted to make sure it was not being caused by the rs , It had a bad vacumm line it was replaced and now it does not want to idle, thanks for everyones help
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
