2005 armada bypass
northern
Copper - Posts: 154
Posted: November 05, 2008 at 9:18 PM / IP Logged
I am looking for a bypass for a 2005 armada (without using a key). Bypasskit.com says XK07 will work. However if you download the install guide it tells you that you have to use the special DATA To DATA cable only available on some remote starters.
So you can't use the
GOWR
Ground
12V
like on most bypass kits. Any options? Also how easy to program a 3rd key? Dealer only?
robertsc
Copper - Posts: 337
Posted: November 05, 2008 at 9:44 PM / IP Logged
w2w should work
it shows data as an option
another-kelly
Silver - Posts: 618
Posted: November 06, 2008 at 8:42 AM / IP Logged
robertsc wrote:
w2w should work
what he said
Chris Luongo
Platinum - Posts: 3,746
Posted: November 07, 2008 at 8:36 PM / IP Logged
The only time D2D is a requirement on the XK07, is to do doorlocks on 2008-2009 Honda Accord.
By the way, my co-workers tell me it doesn't work on the Accord anyway. They tried it, it didn't work, and they had to pull it all back out.
But on the Armada, it'll work just fine wire-to-wire.
northern
Copper - Posts: 154
Posted: November 10, 2008 at 10:03 AM / IP Logged
Yep thanks guys. I had the manual to do an accord D2D. But then downloaded the instructions for the armada and it worked good.
