2008 subaru impreza, remote start
oldsmobile94
Copper - Posts: 51
Posted: November 12, 2008 at 5:06 PM / IP Logged
hey im looking for the information/wiring diagram to install a remote starter in a 2008 Subaru Impreza. i seen the diagram for a 2002 but not to sure if it will be tha same color wires. any help would be appreciated thanks.
tk
Platinum - Posts: 13,725
Posted: November 12, 2008 at 8:38 PM / IP Logged
WIRECOLORPOLARITYLOCATION 2008 subaru impreza, remote start -- posted image.
2008 subaru impreza, remote start -- posted image.BatteryWHITE(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.Ignition 1GREEN(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.Accessory 1YELLOW(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.Accessory 2BLUE(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.Starter 1WHITE/ BLACK(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
2008 subaru impreza, remote start -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2008 subaru impreza, remote start -- posted image.Key SenseBLACK/ WHITE(+)IGNITION SWITCH HARNESS
2008 subaru impreza, remote start -- posted image.TachometerGRAY/RED(AC)IN HARNESS TO GAUGES
2008 subaru impreza, remote start -- posted image.Speed SensePINK/GREEN(AC)IN HARNESS TO GAUGES
2008 subaru impreza, remote start -- posted image.Parking LightsBLACK/ WHITE(+)IN HARNESS IN DRIVER KICKPANEL
2008 subaru impreza, remote start -- posted image.Low Crr. Pk LightsBLACK/ WHITE(-)AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
2008 subaru impreza, remote start -- posted image.Brake LightsRED / WHITE(+)AT SWITCH ABOVE BRAKE PEDAL
2008 subaru impreza, remote start -- posted image.Reverse LightsBROWN / YELLOW(+)IN HARNESS IN PASSENGER KICKPANEL TO REAR
2008 subaru impreza, remote start -- posted image.HornRED / WHITE(-)AT BODY INTEGRATED UNIT UNDER DRIVER SIDE DASH
