2008 dodge caliber rear defrost activation
martinj
Posted: November 15, 2008 at 5:01 PM / IP Logged
Where do I tap in to activate rear window defrost from aux. output of my remote star unit?   &  Is the activation + or -.
martinj
Platinum - Posts: 13,726
Posted: November 16, 2008 at 1:33 AM / IP Logged
When you press the switch, does it latch in?   Does your remote start unit have provisions for a latched output?  Do you have access to a volt meter?
chriswallace187
Gold - Posts: 1,661
Posted: November 16, 2008 at 5:16 PM / IP Logged
Most of the Chryslers where I've attempted rear defogger connection have had a multiplexed defogger control done via the control panel and the BCM - the easiest way to control it via remote start is by tapping the control terminal of the relay.
C Renner's Auto Electronix
martinj
Posted: November 16, 2008 at 5:41 PM / IP Logged
My remote start ia an audiovox  aps687a with a channel 4 latched output.  I do have a volt meter.
martinj
