2004.5 chevy silverado, clifford 70.5x
thepunisher
Posted: November 18, 2008 at 9:01 AM / IP Logged
I am trying to install the Clifford 70.5x alarm / remote start.
I have the XK01 AMDL interface
Also installed the voice alarm
Added a Motion Sensor also.
I thought I had everything installed, but I set the alarm and then try to remote start and it starts and stops right away, but if I turn the alarm off, it starts and stays.  Also It wont let me program it, I do the door open turn the ignition on then off and press the button, nothing happens.
When I set the alarm I get a hood trigger pop up on the remote and I had it connected and then disconnected it and it still happens.
On the XK01 where does the violet/white Door Sense Trigger connect to on the alarm system
Also the Orange wire, (-) Disarm Output, cant figure out where to connect it.
Some things I dont have hooked up on the alarm are
H1/6 Violet + Door trigger input zone 3
H1/7 Blue - multiplexed input zone 4
H1/8 Green - Door trigger input zone 3
H1/9 BLACK/ white - 200ma domelight supervision output
H1/11 White - +/- Selectable light flash output
H2/1 Light blue - (-) second unlock output
H2/4 GREEN / WHITE - (-) Factory alarm rearm output
H2/6 light GREEN/ black - (-) factory alarm disarm output
H3/5 blue/white - (-) 200ma 2nd status/rear defogger - latched/pulsed
If I need them hooked up where do I do that.
Any help would be really great
Thank you
Randy
2004.5 Chevy Silverado 2500hd Diesel, 16" Lift custom stereo, 40" Tires
thepunisher
Posted: November 18, 2008 at 9:02 AM / IP Logged
This is on my 2004.5 chevy silverado 4d diesel.
Thank you
thepunisher
Posted: November 20, 2008 at 1:55 AM / IP Logged
Any HELP?
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
