viper 130xv, 1999 honda
fadedcactus
Posted: November 18, 2008 at 10:49 PM / IP Logged
Hello all,
We installed the viper 130xv + bypss into out 1999 Honda recently. The problem we are having is that the car will start  (after pushing the button), but turned-off almost immediately. However, it sems that if the car is warm up in advance than there's no issue. Is this a remote starter issue or the car issue?
Any help would be greatly apprecited. I am a dummy when it comes to this stuff.
blanx218
Silver - Posts: 654
Posted: November 18, 2008 at 11:06 PM / IP Logged
it shouldnt be the car if you only have problems starting with remote start. do you have a tach hooked up? also what kind of bypass did you use. that can help narrow down the problem
fadedcactus
Posted: November 18, 2008 at 11:09 PM / IP Logged
unfotunately, I supposedly had an expert tech installed the starter. He also put in the bypass and I do not know the type. Sounds to me as if I should call the installer?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
