chrysler 300 troubleshoot
paidnfull
Copper - Posts: 125
Posted: November 22, 2008 at 6:59 PM / IP Logged
the cruise controls do not operate after we installed r/s system,
its on a 2007 chrysler 300 with a ungo rs10 and pkuch2x bypass kit
Im troubleshooting it tomorrow I just wanted a heads up from you guys and see if anyones had that problem
Its  the remote start system with keyless No Alarm
tragik
Copper - Posts: 169
Posted: November 24, 2008 at 6:39 PM / IP Logged
I would chech the brake switch and make sure that the R/S is not backfeeding a reference voltage into the car. If you have around five volts on the brake wire it may not turn on the lights, but might freak out the cruise. It might also be a good idea to see if you unplugged anything near teh steering column accidentially.
If you don't see anything, you can try a hard reset on the car.
Key on, unplug positive battery terminal, turn key to crank position for 30 seconds, put positive terminal back on. Chryslers are prone to freaking out from time to time, and sometimes a good reset is all they need.
good luck.
Northstart.....or start it your damn self.
tragik
Copper - Posts: 169
Posted: November 24, 2008 at 6:40 PM / IP Logged
Also, I have seen aftermarket tail lights cause this problem. Especially LED taillights.
JWorm
Platinum - Posts: 2,208
Posted: November 24, 2008 at 8:31 PM / IP Logged
I haven't done a 300c in a few years, but when the 300c first came out they didn't have the modules that interfaced with the MUX wire and you had to use relays/resistors. If the resistance on the MUX wire was not close enough, it could cause issues with the cruise control. I would check that first.
Check the voltage on the MUX wire when starting by key, compared to when starting it by remote start.
paidnfull
Copper - Posts: 125
Posted: November 25, 2008 at 11:48 AM / IP Logged
cool thanks you guys for your input
she never returned for troubleshooting but when she does ill give yall some feedback
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
