F-150 alarm remote start installation
duttyface74
Posted: March 15, 2003 at 5:55 PM / IP Logged
i am planning on installing a alarm remote starter on a f-150 tommorrow is there anything specially i should look out for. for example does it have a chip in the key or pass lock system and what should i do. thank you in advance
duttyface74
Posted: March 15, 2003 at 6:02 PM / IP Logged
i also would like to know if anyone can give the wire diagram for this 2001 f-150
jayts95
Copper - Posts: 150
Posted: March 15, 2003 at 6:19 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|yellow & lt. grn/pur|+ |ignition harness            |
|          STARTER|RED / lt. blue        |+ |ignition harness            |
|        IGNITION|dk. blue/lt. green |+ |ignition harness            |
| SECOND IGNITION|gray / YELLOW        |+ |ignition harness            |
|   THIRD IGNITION|lt. blue/pink *1    |+ |ignition harness            |
|        ACCESSORY|RED / black           |+ |ignition harness            |
| SECOND ACCESSORY|BLACK/ green        |+ |ignition harness            |
|       POWER LOCK|pink / YELLOW        |*2 |passenger kick panel        |
|     POWER UNLOCK|pink/green *8       |*2 |passenger kick panel        |
|       LOCK MOTOR|pink/black          |   |driver kick panel           |
|     UNLOCK MOTOR|RED / orange          |   |driver kick panel           |
|    DISARM DEFEAT|pink/orange        |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |light switch *3             |
| PARKING LIGHTS -|lt. GREEN/ YELLOW    |   |light switch *4             |
|       HEADLIGHTS|RED / yellow          |+ |light switch               |
|     DOOR TRIGGER|blk/yel & blk/pnk   |- |*5                          |
| DOME SUPERVISION|BLACK/ lt.blue       |+ |passenger kick panel        |
| FCTRY ALARM ARM|*6                  |   |                            |
|FCTRY ALRM DISARM|dark GREEN/ purple   |- |drivers kick panel          |
|       TACHOMETER|*7                  |   |                            |
|       BRAKE WIRE|light green        |+ |at switch *3               |
|     HORN TRIGGER|dk. blue            |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|org/wht - wht/blk   |A |in drivers door             |
| RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |drivers kick panel          |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
Notes:
NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 Power this wire if vehicle is equiped with only rear anti-lock brakes. Vehicles with all wheel anti-lock brakes do not have this wire. *2 Negative pulse, type 'B', on keyless entry models. Five wire, type 'C', on non-keyless models, mastered from the driver switch. *3 May also be found at trailer connector next to diagnostic connector under dash. *4 If equipped with autolamps. *5 The BLACK / YELLOW catches the drivers door and the BLACK/ pink catches the passengers door. The wires are found in there respective door harnesses. On the Super Crew the rear door trigger is BLACK/ lt. blue low in the driver kick panel. Use all wires and diode isolate each. See direct fax document #1076 for wiring information. Both wires may also be found at the GEM module located above the fuse box. On models without a dome light delay use ORANGE / lt. green (-) at the light switch. *6 Arms when locked with the door open. To simulate, send a negative trigger to the lt. blue/white wire at the RAP module, located behind the light switch, while locking.    *7 Tach wire: on the 4.2L it is a dk. blue/lt. green at the coil pack on top of the motor. On the 4.6L go to any of the 8 ignition coils and use the wire that is not RED / green. On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors. *8 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1093.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
