Keyless Entry Confusion
altercow
Posted: March 16, 2003 at 7:36 AM / IP Logged
I have a Autodvox Prestige  Remote Strater/Keyless Entry system (APS 685).   I got the Remote Start to work perfectly (it's been great this winter). My problem is I never got the keyless entry to do anything.
I have a 2001 Dodge Stratus SE 4 door.   The Wiring chart I have reads  it's a single wire set up  "Lock is positive thru a 1800 ohm resistor and unlock is positive thru a 750 ohm resistor.  Must use relays"
I found the resistors, bought 2 relays, I'm just confused on which wire goes to which part of the relay.  Here's the wires I have:
From the Keyless Entry:
Green is Positive lock, negative unlock
Red is Negative lock, positive unlock
RED / Black is Negative 2nd unlock
The vechile is just the WHITE/ Dark Green wire on the BCM (I found this after hurting my back)
If anyone knows of a diagram it would help me out competely.
auex
Platinum - Posts: 5,041
Posted: March 16, 2003 at 8:42 AM / IP Logged
Keyless Entry Confusion -- posted image.
It is similar to this. Just put the resistors on thirty of the correct relay then join them and connect them to the lock wire.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
altercow
Posted: March 16, 2003 at 9:51 AM / IP Logged
I wired it up.  I hear one relay clicking but the door locks won't move.    Could I possibly have the resistors wired n reverse.  Is there a direction they need to go?
Only one relay clicks also? the lock side.
I'm not electically inclined.  But in my mind don't you need a ground somewhere?  Is the 85 and 86 be a ground instead of having two power sources to the relay?
securinu
Silver - Posts: 772
Posted: March 16, 2003 at 11:35 AM / IP Logged
what wire color are you tapping into??? it should be WHITE/ green .here is a diagram.
stratus4door.pdf
altercow
Posted: March 16, 2003 at 12:11 PM / IP Logged
I'm tapping into the White wire wth the dark green strip.
I thought I had my meter but my Dad borrow it without asking. (why did I give him a key to the garage)   I'm going to get it back from him and test the resistors and that wire to see maybe I don't have the right Ohm need or maybe I was sold the wrong resistor.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
