cadillac keysense
absolutepower
Copper - Posts: 98
Posted: December 12, 2008 at 4:17 PM / IP Logged
i did a ungo remote start in a 96 cadi deville. everything works. problem is traction control light is now on. ive talked to tech support and theve advised me to find a second ignition and a keysense. i have found the second ignition but no sign of a keysence. does anyone know where a keysence wire is on a 96 cadillac deville. the sooner i foind out the better
Chris Luongo
Platinum - Posts: 3,746
Posted: December 12, 2008 at 4:39 PM / IP Logged
Keysense is on GM cars is almost always light green, negative trigger.
I've never needed keysense on one of those, though.
If you were missing the second ignition before, and you got it now, you're probably fine. Disconnect the battery for a few minutes, reconnect it, and see if that traction light went out.
absolutepower
Copper - Posts: 98
Posted: December 12, 2008 at 6:27 PM / IP Logged
yep sure did. got second ing. then pulled all fuses and reset with batt all good now
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
