Tach Wire for 99 Mustang
gpgtp00
Copper - Posts: 81
Posted: March 16, 2003 at 7:16 PM / IP Logged
Can anyone tell me exactly where it is. I checked both of teh wires that were listed in the Diagram i got here and both of those register 12V when the ignition is on. ???
jrilla
Gold - Posts: 1,498
Posted: March 16, 2003 at 7:21 PM / IP Logged
Yor tach signal should measure between 1 and 6 volts AC when the engine is running and it should increase when the gas pedal is pressed. Test those wires again with your DMM and make sure you have it set to AC and not DC because the tach signal is in AC, not DC like the battery. I just wanted to be clear about that to save you from saying; "Are you sure that you dont mean DC".
J Rilla
Owner/Installer
gpgtp00
Copper - Posts: 81
Posted: March 16, 2003 at 9:52 PM / IP Logged
=\ that was my problem. Thanks man.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
