'09 mini cooper speed sensor wire
daprince2k
Member - Posts: 6
Posted: December 26, 2008 at 3:50 PM / IP Logged
I am installing a Clarion NAX980HD in a 2009 Mini Cooper, and I need help find the speed sensor wire. I also need the reverse light wire if possible.
R.C. Custom Audio
Posted: December 26, 2008 at 4:20 PM / IP Logged
You'l need a CAN adasptor for this, BMW Minis have always been CAN data rather than analogue. Go to the rear lamp, see which cable goes to 12v+ when you select reverse and trace this forward to the floor loom.
daprince2k
Member - Posts: 6
Posted: December 26, 2008 at 5:01 PM / IP Logged
What is a CAN adasptor?
R.C. Custom Audio
Posted: December 26, 2008 at 5:37 PM / IP Logged
At which point I have to ask if you wouldn't rather take this to pros and get them to install this. Have you attempted to remove the h/unit yet? You do realise it's part of the speedo?  My aplogies, didn't edit post, I meant CAN adaptor.
daprince2k
Member - Posts: 6
Posted: December 26, 2008 at 8:04 PM / IP Logged
I removed the headunit, but I put it back in. I just moved the a/c unit and window controls down, then cut in and hooked up the clarion VRX785BT headunit. I didn't want to tap into any of the speedometer wires until I new which wire was which.
R.C. Custom Audio
chriswallace187
Gold - Posts: 1,661
Posted: December 26, 2008 at 10:42 PM / IP Logged
I'll have to say I'm equally interested in seeing how you're going to mount that Clarion and integrate it with the factory stuff. That's quite a dash design they've got on that vehicle.
C Renner's Auto Electronix
tedmond
Gold - Posts: 4,610
Posted: December 26, 2008 at 10:57 PM / IP Logged
he is currently working or worked at R.C. custom audio so he should be able to rig something up. Im really interested to see this custom job as well. post pics when your done !
daprince2k
Member - Posts: 6
Posted: December 27, 2008 at 4:54 PM / IP Logged
I'll post the pics when I'm done, but I still haven't been able to find the speed sensor wire, I guess I'll send it to a mechanic shop and try to see if they have a CAN adapter. Thanks for the help
R.C. Custom Audio
