intelliguard 950 siren
stru8n
Member - Posts: 15
Posted: December 28, 2008 at 11:51 AM / IP Logged
hi guys new to here and hoping someone can help me. i bought a second hand clifford intelliguard 950 with intellistart 4 added. now this came out the same car as i have so it was easy to wire in i got it all working apart from the siren it wont chirp and wont make any noise even when the alarm goes off.
i contacted the guy i got it from and he assured me it was making a noise when he sold me it and confirmed he had not changed any of the plugs around i checked the wires to the siren while i set the alarm off now the red is getting a constant 12v but i dont know what should be going to the other wires there is red,black,yellow and green i think.
any help would be great thanks and merry xmas guys
OmarR
Copper - Posts: 162
Posted: December 28, 2008 at 2:30 PM / IP Logged
The siren has an internal battery that charges only when the car is running.
I would drive the car for several days and then see if your chirps and panic return.
If not, then get a new siren. 515C I think is the one you need and they are on ebay all the time.
stru8n
Member - Posts: 15
Posted: December 28, 2008 at 3:03 PM / IP Logged
i dont think its that as if it was it would sound when the alarm goes off if the internal batt is flat all you lose is your chirps unless you dissconect the battery
Posted: December 28, 2008 at 4:05 PM / IP Logged
Normally the batteries fail, you will get the alarm sounding but not the chirps. If you've neither check the fuse on the siren lead at the alarm CPU. By the way it costs almost as much to get  the batteries from Maplin as to buy a new siren.
stru8n
Member - Posts: 15
Posted: December 28, 2008 at 4:23 PM / IP Logged
hey thanks for reply.
i have checked the fuse and thats okay like i said it is getting 12v to the siren but i just dont think its getting a signal from the brain. because the alarm has intellistart fitted there are lots of wires and plugs that are the same and i dont know if one is maybe in wrong.
im pretty sure the siren is good as i trust the guy i bought it from im really confused with this one.
does anyone know what wire to probe to the siren to check for a pulse or signal? thanks guys
Posted: December 28, 2008 at 5:11 PM / IP Logged
If the fuse checks out, there is nothing else you can do the red is 12v+ the black is ground and the green and yellow are data, you can't test them and you've wired something wrong!  I would contact a competent installer and have them check it out and re-install if neccessary by the way what car make model year is it.? The Intellistart would have nothing to do with the alrarm's functioning except that 2amp fuse I mentioned also controls the data signal to the Intellistart and if that fuse is blown the Intellistart won't function.
stru8n
Member - Posts: 15
Posted: December 29, 2008 at 2:37 AM / IP Logged
the make and model is a nissan sunny gtir 1990. intellistart is working fine .
most of the wires are coulor coded  and some only fit in one port but there are a few that are the same i think its the data port ones the 3 pin plugs. is there a special way that they should be wired in? or is my siren goosed cheers
OmarR
Copper - Posts: 162
Posted: December 30, 2008 at 9:37 PM / IP Logged
Howie, i know you are the clifford guru...but in my experience, dead batteries in the G4 sirens have stopped both my chirps and panic output. Maybe it was just my bad luck?
Stru...I am assuming you have checked the programming grid to make sure that all (or any of the 6) siren sounds are set to on and that long term chirp silencing is set to off?
stru8n
Member - Posts: 15
Posted: December 31, 2008 at 3:54 AM / IP Logged
hi omar
No i dont have a cliffnet cable for my alarm to check the settings.
But i thought that the alarm could not be turned off only the chirps and i have asked the guy i got it from and he said the alarm and chirps were deffinatly switched on and working.
So its either that the siren has been damaged in transit or there is something plugged in wrong.
Do you think that if i took it to a alarm specialist they would test my siren?
thanks for the replys guys
Posted: December 31, 2008 at 8:13 AM / IP Logged
Omar, the UK spec Clifford Cat l uses the siren's batteries to generate chirps and the alarm to generate alarm engaged sounds. The 950 was the upper level Cat 1 alarm, the Concept 650 was the lowe level think 550 with armoured CPU, battery back up siren. All are obsolete, replaced with Concept 650 Mk ll, this is  a 950 with just a dual zone prox and the latest remotes.  Please Omar don't encourage owners to use the Wiz, it's glitched enough!
Page of 3
