yukon rear hatch help
bsambrano
Member - Posts: 11
Posted: March 17, 2003 at 7:18 PM / IP Logged
I am nearly finished with my install of my 790xv in my 99 yukon four door tailgate style. I was wondering if the wire that goes to the trnk hatch release is driving a relay or a motor ? I only have (-) trigered outputs left so if its a positive trigger can i use a 451m to make this work.
draasch
Gold - Posts: 2,172
Posted: March 17, 2003 at 10:08 PM / IP Logged
Trunk Release BLACK (+) CONVENIENCE CENTER MODULE OR RKE *
* Convenience Center Located Under Driver Dash: RKE Located Right Of Steering Column, On Steering column Support Bracket
im not sure what a 451m is.
if you have a neg. output, then you can wire it up like this:
pin 86 and 87 fused 12v
pin 85 neg output from alarm
pin 30 positive output to trunk release wire.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
