ads dlsl 2008 silverado
jb88ci
Posted: January 09, 2009 at 2:55 PM / IP Logged
Installing a prostart and ads-dlsl in a silverado. Both the remote (yellow wire) and the ads unit (pink) require ignition hookup and suggest the same wire from the (pink) from the ignition harness. Is this correct or is the wire not used?
jb88ci
Posted: January 09, 2009 at 3:09 PM / IP Logged
another question..i was going to do a type 3 install but an installer at crappy tire told me he does type 2 installs on these without the induction ring..told me to do that...fact or fiction?
Mike M2
Platinum - Posts: 2,652
Posted: January 09, 2009 at 5:57 PM / IP Logged
I don't understand the "remote(yellow wire)" part of your question, is that the ignition wire on the Prostart? The ADS pink needs ignition, which is pink at the switch. Your RS igntion wire needs to connect here too. Follow the Idatalink instructions to a tee and it'll work fine. There is a note on the type 2 page telling you you must connect igntion and accessory from your RS unit.
You have it backwards, 2 is with the ring. The difference is the current draw at idle, 2 draws 7ma and 3 draws 30ma. If you want a dead battery after you let your truck sit for a few days use type 3. I ALWAYS install type 2 with the ring....
Mike M2
Tech Manager
CS Dealer Services
jb88ci
Posted: January 09, 2009 at 7:22 PM / IP Logged
perfect..thanks..you answered it..yes, ps has a yellow wire to ignition as well..so two wires to ignition...and yes, the crappy tire installer told me he does type 2 with no ring and it works..even described hooking the interface to teh obd2 wire...claims he does it all the time
loneranger
Copper - Posts: 572
Posted: January 09, 2009 at 10:51 PM / IP Logged
What are the astericks denoting on the following wires, for the ADS-DLSL module?
  • *TACH (AC) OUTPUT - PURPLE / WHITE
  • *DOOR STATUS (-) OUTPUT - GREEN
  • BROWN / RED - GROUND*
  • BROWN / YELLOW - HOOD (-) OUTPUT*
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
