how to wire a relay to do anti grind
kassdog
Copper - Posts: 257
Posted: January 10, 2009 at 11:35 AM / IP Logged
I'm having a major brain fart and can't figure this out. I'm installing a basic remote start(avital 4113). The customer requested to have the anti grind feature put on. How do I wire up a relay to allow this for the customer. Thanks.
jacqueslacombe
Copper - Posts: 124
Posted: January 10, 2009 at 11:42 AM / IP Logged
use the out when runnig or the second ing to a relais that cut the starter when the car is remote started this is a basic installation you shoud be able to figure out hope this will help your installation
cocolaboy
myinstallguy
Member - Posts: 28
Posted: January 10, 2009 at 11:50 AM / IP Logged
Wire a starter disable relay (cut vehicle crank wire: switch side to 87a / motor side to 30) with the neg input (noramaly pin 85) connected to your GWR. Make sure your start output is on motor side of cars crank wire.  Diode isolate relay from any other circuits you may have connected to GWR.
Connect 86 to switch side of start wire.
*Installer since '89*
jacqueslacombe
Copper - Posts: 124
Posted: January 10, 2009 at 11:53 AM / IP Logged
use pin 85 to +ign  and pin 86 to out when running or second ing output( - trigger)   then use pin 30 to 1 side of the starter wire that you previously cut to do the anti grid  and attach the the pin 87a to the other  stater wire  dont forget to solder the starter wire of the remote starter to the one going to the car side not the ignition key side
cocolaboy
kassdog
Copper - Posts: 257
Posted: January 10, 2009 at 12:01 PM / IP Logged
Then do I connect the starter wire coming from the brain after or before the relay. Or do I attach it to the relay.
myinstallguy
Member - Posts: 28
Posted: January 10, 2009 at 12:24 PM / IP Logged
As Jac just wrote, to the side going out to the starter.
kassdog
Copper - Posts: 257
Posted: January 10, 2009 at 12:50 PM / IP Logged
Cool thanks for the help guys. This is why I love this site.
