where to mount anti grind relay
ragj1976
Member - Posts: 19
Posted: January 24, 2009 at 5:25 PM / IP Logged
Hello, about to attempt an install in a 2006 Mazda Tribute. I have done alarm/remote starts before in a former life. Where do you suggest to mount the anti-grind relay? Should I run some leads from under the dash to the starter wires in the ign column? Or try to stuff the relay IN the ignition column?
Should I use 10GA, 12GA etc for the starter?
-Roger
ckeeler
Gold - Posts: 1,461
Posted: January 24, 2009 at 5:43 PM / IP Logged
what model and brand are you installing?
monty_77
Copper - Posts: 491
Posted: January 24, 2009 at 6:02 PM / IP Logged
just cut the wire from the ignition harness make sure the starter side and the the starter wire from the R/S connected on 30 on the relay and that the key side of the wire is on 87a and connected up your 86 to 12v and then a ground while running wire off the R/S to 85.
As for where to put relay, where it will be the most out of the way for you location should not really matter as long as the connections are right.
monty_77
Copper - Posts: 491
Posted: January 24, 2009 at 6:04 PM / IP Logged
as for the wire size the same as or bigger then starter wire will be fine
ragj1976
Member - Posts: 19
Posted: January 25, 2009 at 9:00 AM / IP Logged
Thanks guys.. Appreciate the help.
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
