2005 silverado, remote start
ironhorsect
Member - Posts: 9
Posted: January 27, 2009 at 7:47 AM / IP Logged
Hey all:
Searched but did not find info that helped....
I have a 2005 2500HD duramax with a viper RS(I did not do this install...bought the truck with it)..I have blown out 2 headlight switches over time...Only the auto feature now works, but the other positioons on the switch do nothing....The RS works well, but the parking lights do not come on in the day and the auto headlights come on at night....
What wires do I need to grab at the switch to fix this...They tagged one, but I have seen schematics with 2 wires needed....Some say grey bleack (-) and brown (+), but I have also seen violet (-)
Brennan
ckeeler
Gold - Posts: 1,461
Posted: January 27, 2009 at 9:51 AM / IP Logged
ironhorsect wrote:
What wires do I need to grab at the switch to fix this...Thanks
Brennan
wires? you need to replace the switch.
ironhorsect
Member - Posts: 9
Posted: January 27, 2009 at 10:12 AM / IP Logged
I realize the switch is gone...But that is the second switch in a a matter of weeks...Don't want to feed another switch to the demons if something is wired wrong...Are you guys grabbing both the brown (+) wire as well as the gray/black (-)?
Brennan
ckeeler
Gold - Posts: 1,461
Posted: January 27, 2009 at 10:26 AM / IP Logged
ahhhh, i see what you are saying now. i ALWAYS use the gray/black negative trigger at the BCM. its all that is needed.
kgerry
Platinum - Posts: 3,455
Posted: January 27, 2009 at 10:45 AM / IP Logged
grey/black in the Brown plug at the BCM (-)
make sure you set your starter for - out... or you'll be replacing BCM's and not switches....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
ironhorsect
Member - Posts: 9
Posted: January 27, 2009 at 11:11 AM / IP Logged
I wonder if they set it up Positive?  Have to check this tonoght when I get home....
Would it make a difference if I grabbed it at the switch or at the BCM?
ironhorsect
Member - Posts: 9
Posted: January 27, 2009 at 6:07 PM / IP Logged
Got it...Set it up positive....The rest of the install is so mint, I am surprised that they missed this.....
B
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
