1996 toyota camry unlock wires
triniforever
Copper - Posts: 323
Posted: January 27, 2009 at 5:49 PM / IP Logged
Are relays and diodes needed ,to be integrated on this car's unlock wire with a keyless entry system.(child safety lock maybe).Any help appreciated.
triniforever
t&t tech
Platinum - Posts: 2,622
Posted: January 27, 2009 at 6:04 PM / IP Logged
what alarm are u installing, most likely you won't need diodes or anything like that, it should be straight negative trigger once there's a rocker switch on the door controlling all four doors
triniforever
Copper - Posts: 323
Posted: January 27, 2009 at 6:06 PM / IP Logged
Its an aps57 prestige r/s and keyless entry
triniforever
triniforever
Copper - Posts: 323
Posted: January 27, 2009 at 6:09 PM / IP Logged
And yes i think there is a control module with rocker switches on the driver's door.
triniforever
t&t tech
Posted: January 27, 2009 at 6:11 PM / IP Logged
it's straight negative trigger you can find it at the power lock control module in the driver's kick,my info says light green and dark green, test to verify,
triniforever
Copper - Posts: 323
Posted: January 27, 2009 at 6:19 PM / IP Logged
Actually i found the wires by testing the lock was actually blue/red and the unlock was dark green ,even the brake and the parking light wires was different than listed here,the reason i asked about the unlock wire,wes that the customer just called me and said lock works but unlock dosen't so i thought maybe child security locks were present,maybe its just a loose wire,he's comming back tomorrow so i'll know and keep u posted   thanks t@t.
triniforever
Mike M2
Platinum - Posts: 2,652
Posted: January 28, 2009 at 7:42 AM / IP Logged
Use light green and dark green to solve this problem. The blue/red is the switch wire, you need the key cylinder wire which is light green. If you lock with the interior switch before you get out the remote doesn't unlock the door if you use blue/red.
Mike M2
Tech Manager
CS Dealer Services
triniforever
Copper - Posts: 323
Posted: January 29, 2009 at 7:14 PM / IP Logged
Thanks mike, but this car is acting crazy for instance if i close the doors and lock the doors with the remote it locks and then if i use the remote to unlock, it unlocks once and then the unlock on the remote stops working and also the unlock button the doors stop working, its really strange,i solved the problem ,i found a green wire with brown dots and double pulsed it and unlock works fine, the unlock button on the door still stops working but oh well.And also if the car is remote started everything worked fine.
triniforever
