remote strart
alfred
Member - Posts: 24
Posted: March 19, 2003 at 5:21 PM / IP Logged
I have a 2001 buick century  and an audiovox aa-rs5cs remote start  and keyless entry system does anyone have the the wiring guide for this car if not for this particular remote then i just need the color of the wires in the wiring harness and which is ignition 1 ignition 2 starter etc. also where to find the door relays and there wires also i believe this car has the vat system in it can i use a relay with a resistor to buy pass it what size resistor if possiable
alfs
RaveChild
Copper - Posts: 54
Posted: March 19, 2003 at 5:29 PM / IP Logged
Here are the wires:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white or green      |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|RED / black           |-  |drivers kick or BCM *2      |
|     POWER UNLOCK|ORANGE / black        |-  |drivers kick or BCM *2      |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|lt. blue            |   |at switch *1                |
|       HEADLIGHTS|yellow              |-  |at switch                   |
|     DOOR TRIGGER|dark blue/white     |-  |drivers kick or BCM *2      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |light in trunk or BCM *2    |
|TRNK/HTCH RELEASE|brown               |-  |BCM *2                      |
|       TACHOMETER|pur/wht or white    |   |ignition control module     |
|      SPEED SENSE|GREEN / WHITE         |   |ECM under hood *3           |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |drivers door switch         |
|  RF WINDOW UP/DN|lt blue - tan       |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|green - purple      |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|lt green - purple   |A  |drivers switch or kick panel|
Notes:
NOTE: This vehicle is equipped with VATS.  Refer to directfax document #1049 for interface information when installing remote start.  *1 Larger of the two at the light switch. Can also find BROWN / white in the passenger kick panel in the harness to the rear.  *2 BCM is to the left of the steering column  *3 ECM is in the air cleaner assembly.
But you will have to use a DMM to measure for the size of resistor you need.
alfred
Member - Posts: 24
Posted: March 19, 2003 at 5:49 PM / IP Logged
Do you have directfax document #1049 for interface info
alfs
Platinum - Posts: 12,488
Posted: March 19, 2003 at 7:24 PM / IP Logged
<"http://www.velocitymotorsport.com/images/security/ball.gif" border="0">
GM VATS bypass Part 1
GM VATS bypass Part 2
