door lock problem, 96 grand am
supradude
Silver - Posts: 915
Posted: February 11, 2009 at 11:14 AM / IP Logged
On my 96 Grand Am GT, the fuses are good and I can hear the locks trying to work when I push the lock buttons, but they won't lock or unlock with the buttons. I have to manually move the locking mechanism. The only relay that I see that works them also works other things, and those things are working.  Sorry for posting in the wrong forum, I didn't notice the "motorcycle".
'85 Toy
airhed692005
Copper - Posts: 72
Posted: February 11, 2009 at 11:24 AM / IP Logged
Hello there are lock cylinders that the lock rode goes into. That is going bad. Most of the time both sides will do it because of the drive side is going bad. What it is doing is shorting out so Just replace them and it should work.
Ronald Bailey Owner/ Installer of VIBRATION CUSTUM SOUNDS. CUSTOM BOX DESIGNER AND BUILDER
TID-896 7" screen,Amp-BX1206d
4/0power/ground cables
4-12 mofos 12ft3 box tuned 40hz DB:163.1
jseibold
Copper - Posts: 98
Posted: February 11, 2009 at 11:25 AM / IP Logged
First I would check the dorr lock relay......it is under the drivers dash high near the kickpanel.  You could use a meter or even an old fashioned test lite...probe the orange wire and it should show a constant 12 volts...next probe the lite blue wire and push the DL switch to lock and this wire should go to 12 volts...then repeat this procedure on the white wire at the relay but this time push the DL switch to unlock and this wire should go to 12 volts.......if you don't get these readings at the relay then move on to the switch....you can carefully pop it out without removing the whole door panel and you will find the lite blue and white wires...probe these wires and work the switch and see if you get the 12 volts as described above....if you don't get the correct readings at the switch then you need a new switch....my guess is that your switch is bad......if you do get all the readings as described then your next step will be to check your DL actuators and you will have to remove the door panel to do that.....Good Luck
Friday, October 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
