alarm help
robHI
Member - Posts: 35
Posted: March 20, 2003 at 11:13 AM / IP Logged
i got a clifford ace 4000 alarm and a 98 toyota avalon. i have a problem with the alarm. my parking light does not blink. another is when i am driving, alarm arms itself led start blinking etc. another is when i disable it to get into my car, not even opening the doors yet, the indicator is on for the doors. can anyone help.
securinu
Silver - Posts: 772
Posted: March 20, 2003 at 7:38 PM / IP Logged
Sounds like a install problem . wrong wires tapped .
Joe O'Byrne
Owner / Installer
draasch
Gold - Posts: 2,172
Posted: March 21, 2003 at 2:46 PM / IP Logged
check your ign. wire (12v switched) you should have a wire that requires 12v when the key is on. sounds like you dont have that wire hooked up. also check the light flash output.should be a fused wire.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
