Please help with installing Dei pager
Lighter123
Member - Posts: 6
Posted: March 20, 2003 at 3:40 PM / IP Logged
Hi,
I have a viper 300 alarm system with a 508d field disturbance sensor. I have just installed the 795w dei pager system. So far all i hooked is the is the door trigger wire and the power wires. I still have zone 1 and 2 open.
Is there any way that i can hook up the pager to the 508d, so that when the inner zone is triggered the pager will go off?
And is there a way that i can hook up the built in shock sensor to the pager?
I have tried looking for some information on this kind of install, but could not find anything.
Thanks for the help.
essey98
Posted: March 20, 2003 at 5:03 PM / IP Logged
How did you hook up the pager to notify you? I'm not sure if your alarm has the horn honk output, but if it does, you can use that signal to activate the pager. (if not, you can just use your regular siren output, but I think the pager might also go off if someone enters the outer zone too...) Then, just hook up your 508d to the appropriate zones.
Lighter123
Member - Posts: 6
Posted: March 20, 2003 at 6:05 PM / IP Logged
The alarm does not have that output for the horn.
So far i have the violet wire connected to a (+) door trigger                                 red to pos 12v, black to ground and the orange to (-) ground when armed.  The field sensor is connected to the port on top of the alarm.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
