factory disarm to unlock wire
timdareez
Member - Posts: 8
Posted: March 02, 2009 at 12:11 PM / IP Logged
question for u all...
when hooking up the factory diarm wire to a unlock wire since it's both a neg trigger should i also diode isolate the unlock and factory disarm wire ???? or just hook it straight up ???
Mike M2
Platinum - Posts: 2,652
Posted: March 02, 2009 at 3:12 PM / IP Logged
Diode isolate. If you don't when you hit the unlock button on the door it will disarm, which you don't want. Sometimes i will use another output for disarm, like the dome light supervision wire. It gives a negative output when you disarm(even tho it is a one minute outpue it still will work fine for disarm).
Mike M2
Tech Manager
CS Dealer Services
