what should a battery sit at
black cavy
Copper - Posts: 78
Posted: March 07, 2009 at 8:46 AM / IP Logged
Hi
What should a Battery Sit at Hooked up with an Alarm overnight
I just bought a Brand New Optima Red Top 800CCA-1000C
I drove the car all around yesterday, Since 3:00PM Yesterday I have been going out every 30 Minutes and Reading it.
When I went to bed at 11:30 it was sitting at 12.73V
I just went out today and its at 12.55V a Perfect battery sits at 12.6 Right
Is it normal to Drop one Full Volt with an Alarm Hooked up and Not Armed
I have a Big Current Draw and I'm trying to find it
That’s why I went and bought a Brand new Optima Battery to Start New
When the Car Runs the Battery Reads 15.01V and then only drops to 14.99v
When I turn the car off it reads 13.05 and Seems to Drop from there I guess trying to get to the 12.6V mark
The Coils in the Alt look Burned and Black now and I hear a weird Noise
Could the Regulator Be Bad and while Charging the Battery to 15.01 Volts Be Draining the Battery when Its turned off.
I even Replaced all the Fuses in the Alarm system in the Fall to Lower Amps and still the same thing.
I'm Getting Midas on Monday to do a Charging Test for $23.99 but don't want them to love up my alarm if they put there tester on.
I would really like some Expert Help on thiswhat should a battery sit at -- posted image.
Posted: March 07, 2009 at 10:21 AM / IP Logged
!2.55 is aceptable after about 10 hours at rest, 15.01 most certainly isn't, your voltage regulator has blown. some of your smaller bulbs should have burned out by now.
black cavy
Copper - Posts: 78
Posted: March 07, 2009 at 11:36 AM / IP Logged
Do you mean at my Cluster??? inside the car
Posted: March 07, 2009 at 12:52 PM / IP Logged
Take your readings at the battery, A) It's more accurate and B) You'll lose about .25V between battery poss and where you were doing it. Turn everything off, keys out of car shut doors, wait 2 mins and with hood open, disconnect battery neg, then set up your DMM to the 10amp (or 20 if it has it), position  and the probes accordingly, take your neg to the terminal and the pos to the disconnected battery wire.  If the alarm is disconnected (fuses out) the average reading should be between 40-70milliamps. Anything approaching 1 amp except on a late Jaguar, BM, Mercedes, Caddy  or car of that  ilk means something is draining though I still suspect  the voltage regulator.
black cavy
Copper - Posts: 78
Posted: March 07, 2009 at 1:12 PM / IP Logged
Thankswhat should a battery sit at -- posted image.
Car is a Cavalier 2.4L
I hope to try this on Sunday if it doesn't rain
What Number should I have if I don't pull the Alarm Fuses 1 amp about(I will be doing both ways With Fuses installed and not installed)
About it might being the Alternator Regulator even through the car is Turned off it still can Drain from the Alternator
I always thought the Battery was like a big capacitor and Filters the Ripple AC from the Alternator. I didn't know the Regulator Could Back Feed and take volts from the Battery and kill it.
Posted: March 07, 2009 at 2:41 PM / IP Logged
Look to about 70miliamps with alarm connected. If set to 10amp range will show as 0.07, no if voltage reg is too high it will cook the battery, bend a vertical plate inside and the battery will fail to take a charge, otherwise your description is correct. Except a cap stores it as current, a battery stores electricity chemically.
Platinum - Posts: 13,725
Posted: March 07, 2009 at 5:08 PM / IP Logged
What brand of digital meter are you using?
loneranger
Copper - Posts: 572
Posted: March 07, 2009 at 5:58 PM / IP Logged
Capacitors store energy chemically, as well.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
black cavy
Copper - Posts: 78
Posted: March 07, 2009 at 9:39 PM / IP Logged
I had a Fluke but was Stolen
So I bought a Cheap DMM that looks like this it's 10AMP MAX
Posted: March 07, 2009 at 10:22 PM / IP Logged
Chances are you have a slightly inaccurate meter.
Page of 3
