1999 grand cherokee security system
steveandtracy7
Posted: March 27, 2009 at 8:47 PM / IP Logged
I have a 1999 Jeep Grand Cherokee which has this system that prevents the ignition working until you insert this small metal pin-like key into a hole under the dash, then remove the key, then the ignition will turn. It is some type of immobilizer system. There are 4 or 5 wires going into this small black box with a blinking red light that is under the dash. I would like to take this out of the system. Can anyone please tell me how to do this? Thanks
steve
mikvot
Gold - Posts: 1,043
Posted: March 27, 2009 at 8:58 PM / IP Logged
Yep, get under your dash and disconnect the wires going to the unit. Your starter wire will be cut...thinking the wire will be yellow, you will need to reconnect the 2 ends of this wire.
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
