95 integra rs and inwells alarm
rsndic
Member - Posts: 7
Posted: April 07, 2009 at 3:37 AM / IP Logged
Hey Guys/Gals,
I have a 95 Integra Rs, with no power door locks. I also wanted to install the Inwells car alarm system (been sitting in my room for about 2 years, Piece of doodie) with LCD pager and remote start! Now my question is, do I need to install power door locks or in the instructions the Central control lock Crods wires to get my remote engine to start or even get the alarm to work? Pretty much, I do not care about Keyless entry. If I can't get the remote engine to work, love it! but Since im lately adding a doodie load to the car and parking in school 8 hr days, I need an alarm for some personal insurance and the Lcd pager!
Any help or input would be Great!
ThanX
Hip Hop For Life!
KarTuneMan
Platinum - Posts: 7,056
Posted: April 07, 2009 at 10:30 AM / IP Logged
First off.... as you can see, it's NOT a good idea to use the word s**t.
Second... is your can a manual transmission?   If your car does NOT have power locks, thats just OK! just don't
forget to lock your doors.  It will work just fine... provided it's an automatic..
Posted: April 07, 2009 at 11:55 AM / IP Logged
So that's what a doodie is. Hi Gary. What are control lock CROD wires?
rsndic
Member - Posts: 7
Posted: April 07, 2009 at 3:47 PM / IP Logged
Yeah, my apologizes for the wording, just frustrated!
It is a Manuel transmission! What do I need to do that is diff from automatic?
Well, for my Teg, ive been reading that people have Negative Touch off with 95 integra!
So this is what is mentioned in the instructions for negative Touch Off, In this order:
orange=has a scissor
White=Close
Yellow=Negative (-)
ORANGE / black=has a scissor
WHITE/ black=open
yellow/black=Negative (-)
I have a 10 pin 10 wire plug!
Colors are in this order:
Purple= high voltage coil (+)
yellow/black=Negative (-) (Control Crod wires)
WHITE/ black=open (Control Crod wires)
ORANGE / black=has a scissor (Control Crod wires)
Yellow=Negative (-) (Control Crod wires)
White=Close (Control Crod wires)
orange=has a scissor (Control Crod wires)
Brown=Directional lamps
Yellow= purple to the 85 (Little Black Pin adapter)
I also have a 5 pin, 4 wire plug in this order:
green=hand brake or ground
white=to lock ACC
Orange= (+) brake switch impuit
Blue= (-) door switch input)
My Question now is, do I still need to connect the control crod wires if i don't have the Power locks wires and can just close them off?
Acura Integra
1994-1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE
IGNITION SWITCH HARNESS
Starter Kill:
   BLACK/ WHITE
Ignition +12 Volts:
   BLACK / YELLOW
Dome Lights/Superv:
   LIGHT GREEN/ RED (-)
BLUE CONNECTOR AT FUSE BOX
OEM Horn:
   BLUE/GREEN (-)
AT RELAY ON LEFT SIDE OF FUSE BLOCK
Power Lock:
   BLACK/ WHITE
IN LARGER OF 2 GRAY CONNECTORS***
Power Unlock:
   BLACK/ RED
BEHIND CRUISE MOD IN DRIVER KICK PANEL
Trunk Release:
   N/A
Alarm Input Wire:
Notes:
** RED / BLACK (+) In 18 Pin BROWN Connector In Driver Kick Panel Can Also Be Used For Parking Lights. *** See Note #201- Negative Pulse Door Lock Diagram.
ThanX for the replies, Much Appreciated it!
Hip Hop For Life!
Posted: April 07, 2009 at 4:08 PM / IP Logged
You don't need the locking wires, what's a crod?
rsndic
Member - Posts: 7
Posted: April 07, 2009 at 5:33 PM / IP Logged
Im guess the lock crods is just a name from the company or it can be a typo of lock cords! But crods is what is in the instructions...
Thank you very much, I'll be installing the alarm this weekend...hopefully all goes well! :D
Hip Hop For Life!
rsndic
Member - Posts: 7
Posted: April 08, 2009 at 5:45 AM / IP Logged
It seems this unit will be garbage! Minus well get a system that has good support, Lcd pager, remote Start, And probably power lock converter!
Any suggestions for a system easy to install, and not a pocket breaker? Noob Here!
ThanX!
Hip Hop For Life!
dswift
Copper - Posts: 396
Posted: April 10, 2009 at 12:04 PM / IP Logged
LOL Crods hahaha. wth I wouldnt put that in my DC2. Ahh hell no. Go and spend some money.
"dont ground out!"
rsndic
Member - Posts: 7
Posted: April 11, 2009 at 4:26 AM / IP Logged
YEah, Will Do! Thinking about the Viper 5900 SST! Should be A good install! and Doing Power lock conversion...might just save the hassle and have the shop do it, then open it up and look at how they did it to understand the wiring and what goes where and why!
Thanx
Dic
Hip Hop For Life!
Posted: April 11, 2009 at 4:42 AM / IP Logged
I've been thinking, if the installation instructions are that carefully translated, what's the rest of the quality like? 95 integra rs and inwells alarm -- posted image.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
