98 infinity q45
ceasar326
Copper - Posts: 239
Posted: April 14, 2009 at 11:40 AM / IP Logged
Customer came with his universal bypass directed model 29402. I'm using the transponder. I've try moving the key changing position on ring but no use. Car still turns off. Any sugestions.
Ive try leaving the key in the cylinder with the bypass unplug "no go"
Ive try starting the car with the key and remote starting to keep it running with out the key in, and the bypass turn on. "turns off"
Ive try moving the key inside the bypass and relocating the ring still "no go"
Could it be the bypass not working properly. I would have one till late thursday to know for sure.
Remote starter use is excalibur of america model rs-22
shaip99
Copper - Posts: 112
Posted: April 14, 2009 at 11:53 AM / IP Logged
if you have tried to remote start it with the key in the ignition and it isnt starting than it isnt a bypass issue
that sounds like a tach issue
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
ceasar326
Copper - Posts: 239
Posted: April 17, 2009 at 3:28 PM / IP Logged
haven checked that, but unit has a voltage sensor as a tach input not sure if that makes any diffrence?
Chris Luongo
Platinum - Posts: 3,746
Posted: April 17, 2009 at 10:47 PM / IP Logged
So which is it you're using, voltage or tach?
ceasar326
Copper - Posts: 239
Posted: April 18, 2009 at 11:05 AM / IP Logged
right now im using voltage
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
