07 Dodge Ram Horn Honks w/Auto Door Lock
mshardee
Member - Posts: 6
Posted: April 19, 2009 at 4:00 PM / IP Logged
I have installed an alarm with remote start and everything is working. The only problem is when the alarm preforms the auto door look the horn honks as if I had hit the lock button on the factory remote. I cant turn this feature off on the alarm and am using a DEI xk532 locks and bypass. Im at a loss any help would be great. If I could turn the factory horn honk off at lock that would fix it but dont know if its possible.
Platinum - Posts: 13,726
Posted: April 19, 2009 at 4:43 PM / IP Logged
If you hit the lock button only once on the factory fob, does the horn sound?
Posted: April 19, 2009 at 7:12 PM / IP Logged
I think the factory alarm is being turned on, surely if ignition sense is correctly wired in this shouldn't happen. I fitted to an 04 Ram using resistors and never had any problems on autolock though I set it for double pulse lock AND unlock.
mshardee
Member - Posts: 6
yes thats the problem. When the alarm locks the doors through the xk532 10sec after cranking the truck the horn honks as if I hit the lock key phob button one time. I can be backing out of a parking space and all the sudden the horn honk scares the **** out of you.
Posted: April 19, 2009 at 7:58 PM / IP Logged
Is there an overhead console with menu options?  Is there a way to turn off the honk horn while locking.
mshardee
Member - Posts: 6
Posted: April 22, 2009 at 8:15 PM / IP Logged
I had a dodge tech turn off the honk when lock feature with a scan tool. Helps to have friend in many places. Problem solved.
Posted: April 24, 2009 at 5:19 AM / IP Logged
Thanks for letting us know how to take care of this problem for future reference.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
