06 grand caravan, remote starter
muaiad97
Copper - Posts: 207
Posted: April 19, 2009 at 11:17 PM / IP Logged
hi all
i was installing remote starter in grand caravan and every thig went good exept at the final step when i was conecting  the bypass madual to the ground out from the auto start unit  ther is no signal from ground out  how i will conect the bypass madual to make it work
any help
shaip99
Copper - Posts: 112
Posted: April 20, 2009 at 2:37 AM / IP Logged
If there is no out put from the brain for ground out then you have a bad module you will have to get another module no other way around that
Take it back to where you got it depending on what make it is you should have a warranty on the brain however many companies won't warranty units that weren't installed by shops so you might be out of luck
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
